New to me 706G
Purchased a 706 gasser this weekend. Will be used for haying. All original and gauges work. It show 3340hrs on it. Rubber is really good.
Had a little problem when pulling up a hill, like it was running out of gas so going to look at it tonight runs good other wise.
Is there anything out of the norm I should look at before putting it to use? pros cons?
Thanks in advance
Matt
(quoted from post at 06:06:48 08/16/10) Purchased a 706 gasser this weekend. Will be used for haying. All original and gauges work. It show 3340hrs on it. Rubber is really good.
Thanks in advance
Matt
Missing or sputtering while going up a hill might indicate the need for new spark plugs and a good, general tune-up. If it is actually starving for fuel, the sediment bowl might need cleaned, or that electric solenoid on the carburetor might be mal-functioning.
Sounds and acts like starving for fuel. I pulled the choke out and it got better but not 100%. I here the electric selinoid click when turning on the key. I pulled the each plug wire off and verified spark/fire while running. Looking at the sediment bowl.
Is there a filter or someithing up in the tank that can get plugged or slow the gas output?
Thanks
The tank may have rust and dirt blocking the fuel outlet. Use a good flashlight to see inside the tank. Hal
PS: Pull the gas line at the tank and see if there's a full stream of gas from the tank. Use a clean container to catch the gas.
