farmall m main oil seal
Hi all i need to replace the main rear seal in my m but can"t seem to get the bottom half of the seal off the crank what do i need to do thanks.
I did spilt it i have to put a new clutch in like i said i have the top side of the seal off but the bottom side of it wont come past the crank. thanks
Its been a while, but seems theres a plate or something there, or maybe some oddball bolts or something. If you have all the bolts out it could just be gasket stuck.
Rear main seal is 2 felt strips, the 2 die cast holders are very prone to warp if you get them off lay on a flat surface to check.
