H drawbar attached to saginaw 3 point hitch
Anyone ever tried adapting the H drawbar to raise and lower with the saginaw 3 point hitch? Looks like the drawbar would need to be a little longer (maybe an M drawbar?) and would need to be bent differently to allow some travel around the bottom of the chassis. I have the part (with several holes) that goes between the lift arms, but most of our implements have tongues that won"t allow very sharp turns. Plus it would be easier to back up to the implement and raise it, rather than jacking it each time.
All my 3pts. have the quick hitches and have down pressure on the 3 pts. (except the M&M M-5 with the factory 3 pt. no down pressure) and I have an attatchment that hangs on the quick hitch. One of these attatchments has a 2" receiver on it. Works good plus easy on and off. Would not be without it. Armand
If you have the swinging part, it pulls from underneath, and can swing from side to side. Other than avoiding having to jack the implement up, there is zero advantage to having it attached to the 3 point. Although Saginaw is heavy duty, putting a drawbar on a three point just accelerates wear.
