606 International Tractor
Anonymous-0
Hi, I am new to this form. I am thinking about buying a 606 International with a loader. The clutch pushes in hard and it takes a while before you can shift without grinding gears. I would appreciate info and is a 606 much of a problem tractor? What problems if any!
Thanks in advance! Case Broke Gary
My 460U clutch wears out my left leg. Gears clash because of main clutch/TA adjustment, although mine still clash after new clutch and adjustment as good as I can get it. Basically the same rear end and transmission as was in the M, which used 90W. There is excess play in the linkage. Clash is worse when the oil gets hot. Might change to 20W trans-hyd fluid, although that is not recommended. Hytran or equivalent is more like 10W. Your 606 is very similar to my 460U. No more real problems than the typical old tractor. You will find water in the transmission and hydraulics. If gas, it will use a lot.
I love a nice 606, but for a loader there are a number of tractors that are just more workable. These transmissions just are not made for changing direction going back and forth, and reverse is very slow.
I agree with that. There was a direction reverser offered for that purpose, kind of rare.
What loader does it have and what do you want to use it for? No one can give much advice till we know what the use will be
I have a 2606 with backhoe and IH3000 loader. Just like any old tractor, it is slow waiting to shift to keep the gear clash down to a minimum. They don't have synchronizers as far as I know. Have gear clash from the shifter and the forward/reverse lever as well. It has a bad gear in it that makes the forward lever kick out of gear. I attached a bolt with washer on the end through a short piece of rubber hose and double nutted on the panel by the dash. It holds the lever in place so it can't kick out.
I watch for steering and hydraulic issues. Still haven't got my power steering up to snuff yet. My next attempt is to cap off the relief lines to and from the oil cooler once I get it running again.
That 3000 loader with the hoe and back for counter weight will lift 1500# bales all day. And because it is slow shifting and has a slow reverse, it takes all day to move bales around. The loader isn't any good for doing any grade/scraping work as the bucket wants to dig in which is assume is a hydraulic issue. If you have much loader work to do, get a skid steer.
(quoted from post at 20:31:46 07/27/10) I agree with that. There was a direction reverser offered for that purpose, kind of rare.
I know this is an old thread but still relevant. I just picked up a 1964 2606 for a very cheap price. It has a smooth running 6 cyclinder diesel engine and was upgrade with an oversized Wain-Roy loader and Wain-Roy backhoe. I have been able to get most of the work done on it (fluid/filter changes, etc). It was sandblasted and repainted by the previous owner with heavy duty case yellow paint. I've whacked on it with hammers on accident and the paint still sticks.
The only two issues that remain:
1. The tractor has a direction reverser. It also has a shifter slot to slide into reverse but the reverse doesnt work from there, it only works from the reverser (which makes sense). However, I couldn't budge the lever for the direction reverser shaft. I finally got it free and it just barely grips the gear to send it into reverse (effectively making it have all gears in reverse) and I have to hold the lever otherwise it grinds. I opened up the cover to take a look and it doesn't fully engage the gear for reverse. I tried every adjustment and it still doesn't slide any further. It has some movement but now whenever I put it back into forward it usually gets locked up again and I cannot get it free without removing the cover and manipulating it with prescision tools (hammer and drift rod haha). Could it be possible that the selector is slipping and going beyond the forward gear (on the engine side) and is preventing me from getting back to neutral or reverse? My guess is that the slide is worn on the selector, does anyone have any experience with this to confirm what I should be looking at to replace first? Or if I can even find the parts to replace it?
2. the brakes need some TLC, that is something that can be addressed in due time.
Thank you for your time.
