Re: A rear wheel problem.
old
A leak and a wobble could well mean a bearing going out and a bad seal of course. I would jack it up on that side and then with a bar etc try to lift on the bottom of the tire and see if you can feel/see slop some place
Old, great minds think alike. somehow this post got split into 2 separate ones. you said the same exact thing I did!!!!!
LOL what can I say I have BTDT to many times and believe me when some one says to you at the gas station hey your rear wheel seem to wobble a lot it makes you think about walking home.
Ok, I'll give that a try. Are you saying that if I can get it to wobble at all when jacked up then its a bearing and a seal? If so, how hard of a job is that to accomplish?
It is not too bad of a job. if you find it wobbles, you have a bad bearing. If you find that, let me know and I can post how to replace.
Great! I've been reading manuals and anything else I could find, haven't been able to figure it out yet. It will be a week or two before I can get to it. Stuff comes up... But I'll check back when I get there. Thanks.
