M sounds lame
Docs69
The old M that I'm restoring has never sounded as good as I thought it should. Is it the muffler or manifold or both? It has the typical Tractor Supply muffler. The 300 we have has the same muffler but sounds great. Any ideas?
Thanks
Lame? Define lame! What work have you done to the engine beside the manifolds? What is the compression? Have you had the tractor on a dyno? No amount of straight pipes, glasspaks, or open mufflers is going to make an engine sound good unless it has been tuned on a dyno AFTER your engine work has been completed. Also the engine should be checked again AFTER it has been worked under load to seat the rings and valves have been readjusded and other minor adjustments have been rechecked. The Tractor Vet and others will no doubt have some other ideas about this as well. Armand
Without any details on the engine or manifold you have. My best guess is the 300 has a higher compression, different ignition timing and different valve timing compared to the M. M engines equiped with higher compression and distributors with a slower and less total advance seem to have more of a bark sound out the exhaust. Also a later replacement camshaft will change the sound some.
