Farmall Super A Sickle ?
tjpocock
New User
I have a 1953 Farmall Super A that came with a 5' belt drive sickle mower. I can't figure out how to mount the mower. It appears to be a belly mount. Can anybody lend a hand or post pictures to help?
I have an AI with the belly mount mower. But missing the lift arm. It mounts on the small part of the drive tube with 4 bolts, and pulley end mounts on the right hand final drive with a mounting plate.That's all I know about it. I'm trying to identify my mower so I can get a lift mechanism for it. See Help Identify. Ron Mn
Thanks for the photo's and info Jim Becker. That looks just like the one I have and I believe I can make it work from your photo's. A picture paints a thousand words. I will post photo's when I get it mounted which shouldn't be too difficult. I have been looking high and low ever since I posted that question and hadn't checked back - My answer was here all the time. Thank you so much.
Hmm. If it looks JUST LIKE the pictures, you have a Cub mower and it won't work on a Super A without major surgery, after which it still won't work very well. If it looks SIMILAR to both on that page, but not identical to either, you are good to go.
You are correct in questioning my wording. Your pictures don't look exactly like the one I have but they are the closest thing I have seen and they make mounting look very understandable. I have not had a chance yet to attempt the mount but am confident it will work as it came with and was used on the tractor by the previous owner. You seem to have some great knowledge of these tractors and thier implements. I live in Spokane, Wa. and thought it would be fairly common knowledge for farmall buffs, but have not found it to be so after talking with atleast 4 different farmall enthusiasts here. Again, I appreciate your input.
