Nevada Dan
New User
I"m adding a 3-pt kit to my 1953 Super M (S/N L509427J), a Stage II, I believe, with the distributor pump and the cast reservoir (P/N 358444R1) under the gas tank. Question: What are the bulges with ports in the cast rear plate of the reservoir? The top one is obvious - it"s plumbed and hosed forward to a T that feeds outlets to both sides midtractor for lift-only (loader, etc). What is the bottom bulge with two plugs (left and right)? Are they pressure and return? Can I use one and plumb it to the rear for lift-only function on my 3-pt? Or should I just T into the upper line I know is pressure, lift-only? For future reference, where do I find a description of the valve functions and ports inside this reservoir??
