If you go to the online parts books and on the first page click were it says "Right Here" in red.
On the next page on the top left in the search bar that says model enter 300.
Then scroll down and click on the IH 300 Utility Tractor.
Then click on Chassis and the click on Chassis, Fuel System for Tractor.
You can then see how and were it is supported.
Part Books
Jeff Z.
Thank you for guiding this old man by leading
me by my nose ring to the info that I needed to
work on this old tractor that I took in partial trade .OUCH
Thanks again
J.Cline
take the steering wheel off (using a beefy puller and wacking the puller drive bolt with a hammer as you tighten)and then remove the cluster section of the body, this will require undoing the throttle linkage and wiring/cable for the gauges, you can just kinda hang the dash/cluster section on the steering column, don't have to totally remove it.
the tank is only held in with a few bolts from the side and will be fully exposed at this point, but first you gotta remove the fuel line etc and with the cluster out of the way it makes the job pretty easy. also be able to clean out alot of crap that gets caught up behind the gauges whilst your at it....
