Sediment bowl packing
WY JERRY
Anyone ever had any luck putting new packing around the valve stem on the sediment bowl assembly? My tractor is a M. If so, what kind of packing, and where might I find some?
Thanks, Jerry
Jerry, I have tryed some fine nylon with greese and it worked for a while. Rice equipment
814-226-9200 has new needle with packing that is your best fix. oldiron29
I have had good luck using a piece of cotton string dragged through a bar of soap and wrapping it around the shaft.
A lot of the originals had backseating stems. There was no packing. If you didn't open them all the way, they would leak.
Learned from the guys on this site.
Graphite valve stem packing. Its a rope like stuff just wrap it around a couple of times and screw in the packing nut on top of it. Probably have to go to a good hardware store to find it.
(quoted from post at 11:35:27 06/18/10) Learned from the guys on this site.
I got a spool on ebay. Kinda spendy, but I have many to do. It has to be packed in there pretty tight to work well.
