Delco Distributor Bushings
Anonymous-0
I have a 1952 DC Case Tractor with a Delco Vertical Distributor PN 1111411. The distributor housing bushing is very sloppy and needs replaced. I know that Farmall and Allis also used this distributor.
Does anyone know where I can find replacement bushings? I have not yet removed and disassembled the distributor. I'm guessing there is an upper and lower bushing?
Thanks In Advance.
Don K.
I asked this about my Farmall C a couple of years ago and they were available. In addition, the replacements are longer than the originals so there is an unworn portion of the shaft to turn in them. Hope someone can supply the source for you. I wound up not needing them, had other problems.
Push the old one out, take it and the shaft to Motion industries (or similar, even NAPA) and they will likely have it in stock. Make sure it is Oilite (sintered bronze) to assure long life. Jim
