756 torque problem
Anonymous-0
Got 756 that when i pull the torque it seems ok but whenm i push lever forward it can take about 15 seconds before it shifts back to high. Any ideas? Thanks
TA is shot.
You can try adjusting everything, but that and $1.50 will get you a cup of coffee.
Sorry to be the bearer of bad news.
could be MCV valve problem, never heard of a TA shot on high side, they usually sit on their tail in the low side, and you do not move if TA shot. throw the lever forward, then clutch the tractor. If tractor works after 15 seconds, does it stay working, then not the TA a problem
