Hydraulic line for 340U?
Anonymous-0
I have sprung a hydraulic leak under the seat of my '58 340 Utility. It is in the hard lines that run from the distribution block under the dash to the rear block (behind seat) for the fast hitch.
I don't know what is the best option for repair at this point - source a replacement or see if I can get someone to braze the lines?
(quoted from post at 05:08:32 06/05/10) I have sprung a hydraulic leak under the seat of my '58 340 Utility. It is in the hard lines that run from the distribution block under the dash to the rear block (behind seat) for the fast hitch.
The leak is probably from rust, so you will have to replace most of the line. Mine was replaced with hose by the previous owner. I'm sure that is a much cheaper way to go.
I would take the leaking line to your local hydraulic shop like Colliflower Inc and have a new hose made up with the correct swivel nuts.
Look in your manual to see what hydraulic pressure is on that system. You may need double braided hose to withstand the pressure. Hal
