Hi all. I have a IH 300 Utility, power steering, no TA. Today I changed the trans/rear end oil and the oil in the hydraulic reservoir. For both I used Hydraulic/Trans oil from TSC (Traveller brand). My issue is with the hydraulics. One thing odd about my tractor is that at some point someone ran a return line from the power steering to where the drain plug for the resavoir should be. So I cracked open that line, let the oil drain. When it quit dripping I started the tractor and let the oil from the lines pump out (per the manual). I refilled. Then with the plug out, I tried to cycle the hydraulics to fill the lines and flush the air, but I got nothing. My hydraulic lift cylinder doesn't move, and my power steering doesn't work. I drove it about 30 yards hoping to get it to work, but nothing. Any idea why? Do I need to bleed something or what? Any help appreciated because I'm really getting frustrated. Thanks.
