Farmall H rear Steel what are they worth?
I maybe be getting a set of rear steel wheels for a Farmall H I think there in good shape and they have the wheel clamps with them. What are they worth? Is there anything I should be looking for before i get them? They are part of a deal I am getting and I would be selling so that is why I need a value to know if I should do this deal
thanks for the help
Chad
Of course check them over real good for any cracks around the clamp area(and everywhere else)...make sure the threads for the bolts are ok, etc...nothing worse than selling a part with a fault that you hadn't noticed, because you can be darn sure the buyer will notice it!
Make sure you measure the axle on your H and the hole in the wheel. The wheels for F-12 are very close to H wheels but center hole is slightly different.
