It won't let me upload the picture from CIH, but I'll be glad to email you the photo and the photos of everything else I already have. I only paid $150. I can resell the tube and tie rods for more than that.
I have the bolster , and the hubs. From what I can tell, on this version, 856 J-15 on the CIH part look up, of the Farmall HD adjustable WFE, this is what I'm missing. I'm just trying to be as certain, as possible, before I start taking things apart and realize it's going to be a week or two before I get the missing parts.
17 1 405459R1 Arm Arm, Steering Knuckle Lh
1 427546 Nut Nut, 1-3/8-12 Hex. Jam
1 Q326 Washer Washer, 1-13/32 X 2-3/4 X 18 Ga
21 1 405460R1 Arm Arm, Steering Knuckle Rh
22 2 369131R91 Bearing Bearing, Steering Knuckle Pivot Thrust
23 2 15943DA Sealing Washer Sealing Washer, Steering Knuckle Pivot Felt
24 2 146008R1 Washer Ring, Steering Knuckle Retaining
2 193-12 Lock Washer Washer, Lock, Ext Tooth, 1/2"
25 2 401768R92 Steering Knuckle Knuckle W/oil Seal, 370254R91 And Shield, 48701D, Steering
2 427645 Slotted Nut Nut, 7/8-14 Slt Hex.
2 108643 Cotter Pin Pin, Split (cotter), 5/32" X 1 3/8"
26 4 358958R2 Bushing Bushing, Steering Knuckle Pivot Pin
27 2 80722 Lube Nipple Fitting, 3/16 Drive Type Str Lub
As many of you have previously attested, it's easier to show the wife what a great deal I got, and nickel and dime the parts orders versus explaining the $1300 outright for a new WFE. If momma ain't happy, nobody is. And, if I have to make it up, which I will anyway, I can't work on my tractor if I'm painting and remodelling.
Thanks Again,
Matt
