glennster
any way to bench test or adjust a 6v pos ground v-regulator? bought a brand new one last year from case-ih and had it on the shelf. went to put it on my m, nada-zip-zilch. its a made in the usa, went thru john t's secret test proceedure, and the v-reg is the problem. genny will put out close to 25 amps with the field grounded. here is the varmint. maybe i should throw it around the shed a couple times and see if that helps. contacts are all clean and shiny
<a href="http://s121.photobucket.com/albums/o234/glennster_01/?action=view¤t=DSCF2014.jpg" target="_blank">
</a>
Untitled URL Link
Untitled URL Link
