Farmall 100 12 volt wiring diagram
Jan- I am looking for the 12 volt wiring and I don't see a diagram for an A or A1 on what you attached. Am i missing it? Thanks. John
Diagram #2 is identical to the components on a 12v generator based system. Including voltage regulator and lights. If yours has an alternator, with negative ground, or a generator with Negative ground, the + and minus signs just change.
With an alternator (Delco 10SI or equal 3 wire) the diagram for that charging system is included (Its diagram is #5 They are essentially the same on any farmall letter or X00 series. if yours has a relay (solenoid) start (push button start) it will have that circuit going from Amp gauge load side to the push button then to the starter relay S terminal. Best of luck Jim
