I have a '73 IH 656 Utility with a T/A. When the T/A clutch lever is pushed forward, in Direct Drive, the T/A clutch is engaged, correct? (DD on the tach and the tractor is moving faster). When the T/A clutch lever is pulled back ("T/A marked on the tach and the tractor is moving slower) the T/A clutch is disengaged. Is this correct?
So, if the T/A clutch is slipping, you will notice it in Direct Drive, or when the clutch lever is pushed forward. Correct?
Happy Easter and I appreciate your help!
-Bill
-Bill
