ih 200 spreader tires
Are you taking the size of the tire from the side of an old one or from measuring the rim? I'm suspecting that's a 20" tire, unless your rims somehow came off of something else.
I believe the spreader came with 7:50 x 20 implement tires. I have never known of a 22 inch implement tire.
Harold H
Sorry forgot to also add I also have and extra set of rims I made one spreader out of 2 and also have some other extra parts.
If I remember correctly Miller tire has them. I was looking at an old Oliver hay rake a few years ago that was in good shape but the tires were gone. They were awfully expensive and I gave up o the rake. If he doesn't have them then they probably aren't available.
You must be measuring the overall diameter of the rim to get 22". If you measure where the bead seats you will measure 20 inch for the 7:50 x 20 tire size previously stated. Any good agricultural tire store should be able to get 7:50 x 20 implement tires for you.
Harold H
I have 3 IHC 200 spreaders. I got the 750-20 tires from a Titan tire dealer. Titan makes a 750-20 implement tire with a closed bar. Open bar was what they came with new but I do not know where to find those. These are close.
