340 utility hydro valve control handles needed
B Peppler
Hello I have a 1961 International 340 Utility it had only the Tele-Depth valve on it. I found two valves for remotes. I can"t find the Hydro touch handles. On the Case IH parts site I need the 205 Hydra-touch system. Does anyone have a parts tractor they would sell the handles and linkages for the 340. It looks like 460 would work also. Thank you, Brian
Try Mike at Steel Wheel Ranch - 785-548-7437. If he has one he prefers to sell the whole unit. Other possibilities are Bates Corp and Wengers. Be aware that on the row crop and utility there will be differences. The tel-a-depth control on the row crop is attached to the dash in line with the remotes as opposed to by the seat on the utility.
b; try this link for JP Tractor. Me thinks Paul might have had an old link or puter trublzz. Maybe you have/could also post a FREE ad in the classified section. Good luck w/you 340 project.
J P Tractor link
