765 Diesel Hydraulics
Clynnt
New User
I have a 1970 IH 756 Diesel. It has 2 hydraulics remotes. is there a place to pick up power beyond to go into another 2-spool valve so I have 4 remotes ??
Thanks
Yes,you need a powerbeyond plate .it attatches to the side of the valve body. go to RedRunRite for parts
There is a power beyond plate, but you will also need a different valve body.
The outer valve body has the end plate cast as part of the valve body. It is not removeable. You will need another "second" valve body in order for the power beyond plate to work.
AFAIK, only the early 06 series came with a separate end plate that could be easily removed and converted into power beyond.
