Farmall F-12 single front wheel question
Dave13
New User
(casting # 26046DAX) i was wondering if there were any bearings or cast bushings or anything in the wheel to be replaced. my wheel seems to be worn some and i would like to make it tighter. Thanks
There are two big cast iron bushings. I had the same issue with my F12. Instead of trying to search for good ones, I fixed the originals. If you are good with a welder and a lathe you can do that yourself or take them to a machine shop. On mine I also had to weld up the axle shaft and turn it true again in a lathe. Than I used the lathe to drill/reem out the center of the two busihngs so they were true again, than pressed a brass bushing into each, to fill the new gap, and so that they would wear rather than the cast pieces. After that I just sized the bushings for the new axle diameter, put it back together and its good as new.
Hope this helps you
-Jordan
When you get it fixed remember to grease the tar out of it every time you run it. I had the one on my f-12 try to seize up one time. Not fun as I was miles from home where the grease gun was.
