will this loader fit my mta?
Case e
Just wondering if a Mcormick No. 52 will bolt right up to my MTA. It is currently on a 656 and was on a 560 before that. I was just hoping it would fit without having to do anything to it as it will go back onto the 656 after it gets a new clutch. thanks Case e
The MTA is slightly shorter than both the 656 and 560 due to the 4-cylinder engine. However the frame rail width is the same on all of them.
Does this clamp over the axles, and bolt to the frame up front?
