38 tires on a Super C
Dean Olson
I have good 11.2X38" tires and rims off of a Farmall H and need new tires for my Super C. It looks like it would be cheap and easy enough to weld in some bolt loops and make the H rims work on the C. Has any body tried this? Pros and cons? Thanks
You know, that doesn't sound like a bad idea at all.
It would only raise the tractor by 1".
However, it will make the tractor much faster in all gears. If you're just "tooling around" with this tractor, no problem. They might be too tall if you're actually trying to work the tractor.
Dean, We did this afew yr's ago and It work's great plus if you ever need to replace them they cheaper than 36" . Easy job good luck GENE
As mkirsh stated, it will kill the pulling power, and increase the speed in all gears, which are too fast already, depending on what you are doing. If you don't use it for that, probably ok.
