Anonymous-0
Bought an International 1066 tractor but it has a steering problem. When you turn to the left it steers pefectly very easy to turn, but once you get the tires straight and try to turn to right it is very hard. It feels as though the oil from the cylinder from the opposite side is not returning back. You put pressure and release the steering wheel and the steering wheels moves back in the opposite direction. This past weekend I put good pressure to turn it to the right while the tractor was idiling and once of bolts from the bottom of the steering pump broke off from the thread: I have changed the oil and new filter in the transmission, removed the two (2) valves that go on the right of the mcv pump and it still does not work. Please help need advice. Previous owner informed that was the reason he sold it.
