856 fuel pump
david kline
New User
i having problems with it staying running it will start but it dies out and shuts off there is a bolt back fromn injector lines if i loosen that it will rev back up and run normal but it leaks her adeisel what do i do from here any suggestions
Dave,
That's because the relief valve is plugged with debris and when you loosen that bolt the built up housing pressure has a place to go.
See the pictures for your first post on page two?
That pump needs a drive ring.
Allan
