14.9 x 28 Firestones mounted/balanced/loaded
What would be a good price to put new 14.9 x 28 Firestone AG tires on my tractor? (when I drop it off, they have to remove wheel weights, unmount current tires, put new tires on, load them & install back on tractor), just shopping around & don't know what $$ I'm looking at. Thanks
I removed an 11.2x38 and put a 12.4x38 on a rim by hand about a month ago. I took it in the small heated shop so it would not be too stiff. It took me a couple of hours with crowbars and a pinch bar and a tire tool whose name I don't know, but it was sure educational. Just like changing a bicycle tire only bigger. I guess it all depends whether you have more time or money to spare.
Zach
Your looking at around $350-700 each depending on where and who you have do the work. Figure just labor will be $100 plus if you have fluid put in and the tires alone for a cheap ones $350 each if even that low for cheap china junk tires
they dont remove anything, the tires are mounted right on the tractor. only remove and replace the fluid. unless you want to haul the tires in for them then you do the removing.
