M Carburetor
Anonymous-0
I have a 1947 Farmall M. The carburetor needs a rebuild. Cast into the carb body is the number 85570. I have searched the internet and can find no reference to this number. Is this a IH carb? It looks like one, but where the idle jet is, there is a plug in the hole. Will a carburetor kit for any M work? The tractor ran great until recently. I think the E-10 gas is making a mess in the fuel system.
Look on the top of the carb for a round tag about 1/2" in diameter. That has the carb number on it. Casting numbers are not needed.
IF your fuel system is clean to begin with, E-10 or ethanol blended fuel has absolutly no effect on the carb. I have used Gasahol now called ethanol since the 70's with no problems. In fact, ethanol has a cleaning effect on fuel systems.
Just order an M carb repair kit and take EVERY jet out and thoroughly clean the passages.
What you have is a IHC E-12 Carb. It will have Throttle body Number (8557D) cast into the body and a 5 digit number on the Bowl section. EX#(50983DC) You need both to order the correct kit.I know this because I have the same carb.It is a Distillate Throttle body on a Stock bowl..You can buy the kit here,I believe it is BK11V or 12V I 'll have to get back when I check....Your Kit may be different, depending on what bowl you have. They made about 5-6 different combinations!...
Hi Coax, Is the bowl number on the bowl or is it on a little tag mentioned in the other response? I cannot find a number on the bowl, unless it is on the side facing the engine. The tag is missing on this carb.
Thanks, Roger
You guys are making it way too complicated. I keep only the kit for the 50983DC in stock. That kit works on ALL M carburetors.
(quoted from post at 11:40:32 02/08/10)
o answer the first question yes, its on the engine side, and Rusty is right the type he has is the correct one. I only went into detail becase there ARE different kits for different Throttle bodys.. (After much Research).
Good Luck.
Peace
Good Luck.
Peace
P.S. At least you got more answers to this question than I did when I asked it awhile back... :(
