ryanwheelock
Anyone know much about the belly pump upgrade. Found this on a website, www.farmall-h.com under lift-all.
The kick-off pressure is increased, an improvement package (15261-E) was made available which permitted increasing the kick-off pressure of the earlier pumps. Lift-all pumps of early manufacture were set to kick off at 450 to 500 pounds pressure in the system. Later Lift-Alls are set to kick off at 750 to 800 pounds pressure. These higher pressure units can be identified by a yellow figure 8 painted on the outside of the reservoir.
Anyone heard of this before?? Anyone ever upgraded their pump??
