Farmall m wheel hub
Harry Gill
New User
I would like to put wider front wheels on my farmall M tractor and I was wondering if there was a pickup wheel hub that would fit the existing spindles.
(quoted from post at 06:16:18 02/02/10) I would like to put wider front wheels on my farmall M tractor and I was wondering if there was a pickup wheel hub that would fit the existing spindles.
There is a six bolt, heavy duty hub made specifically for an M. I doubt you will find a pick-up truck hub that will work.
Years and years ago I tried a 5 hole 1/2 ton 1956 IHC pickup hub on my Farmall H. I think everything worked, but it would require a much longer wheel bearing cap since the spindle shaft stuck out 1 - 1 1/2" too far. I don"t remember any other details.
