666 loader hookup
MikeinKy
What do I need to connect my loader (IH2250) joy stick to my tractor hydraulics and not use my rear outlets?
On the 666 you have to use the rear outlets unless you want to spend a lot of money. When i had one on my 686 i just used the two outlets and not the joy stick. It worked real good you could even move both once you get used to it. It might be a good thing to take the detents out of the remotes but it works ok with them in also. Erik..
I am assuming you have a gear drive.
1. PTO pump. downside is you lose your pto for implements.
2. search for charles todd's 504 project. Similar hydraulic system so you could do a similar project.
Make sure you joystick valves are for open center and have power beyond.
3. a more restriced flow, less modification and plumbing version of charles' set up is to run the tube at your right foot (currently to the remotes) to the inlet of your new valves, run the beyond/out of the new valves to the remote inlet where the tube was attatched, and the return line to a drain plug or other reservoir path.
(joystick must also be power beyond type, open center)
karl f
