i overhauled my super m during the summer and i also put a new block in it, the block was checked and plained, the head was gone through and plained, everything was checked and gone through. just for the hell of it i loosened the drain plug the other day and about 2 or 3 bottle caps full of anitfreeze came out. the only thing i can think of is that once the head was torqued down i had to remove it rite away and i used the same head gasket but i put copper sealer on it, do you think that maybe the head gasket is bad now? why else would it be leaking antifreeze in the oil? Should i retorque the head and see if that helps or just replace the head gasket or just leave it alone?
