I have a IH 424d with power steering. Front end gets a little lite when lifting a 700 lb box frame harrow. looking at adding front weight to a ih 424. I have a tractor bumper on front, looking at making a bracket to bolt or weld on to the bumper to hold suitcase weights so I can add or take off weights. Parts manual for 424 is showing a 10 hole bracket for 67 lbs or 100 lbs suitcase weights, which i guess the holes is for how many weights can fit in the bracket. I think 400 lbs will be enough, if not i can add more. ANYBODY ELSE HAVE ANY SUGGESTIONS OR HAVE SUITCASE WEIGHTS ON A 424 THANKS
