garyandnancy
New User
I’m working on a neighbor’s cub that will not start, and I’m stumped. When I crank it, it will sputter a bit, sounds like on all four cylinders, but will not run. Here is what I have done:
-Compression on each cylinder is between 90 and 110
-Points are opening just as #1 cylinder is at TDC. I confirmed this with a multi tester.
-Using a timing light, I have confirmed that #1 is getting spark just right at TDC
-Plug wires are correctly connected, 1 – 3 – 4 -2
-I took the carburetor apart, passages are clean, all right parts are there.
-I checked for a vacuum leak on the manifold, was not able to find any problem.
It seems like it should run, clearly I am missing some thing that is messing things up. Any ideas?
Thanks
Gary
Thanks
Gary
