400LP tank covers
*MMIHJD*
Hello, does anyone know where I can get some covers that go over the filler valves on the left side of the tank. I need two of those.
I presume you want the caps that screw onto the valves. I think any LP dealer might have them. Or you could try:
Welters Farm Supply‎
14307 Lawrence 2190, Verona, MO‎ - (417) 498-6496‎
They are nice people. I have recently done business with them regarding my 400 LP Ensign regulator. They are not IH dealers.
They are VERY good people. I have met a couple of the "guys" at sales in the area. They mostly deal in Minneapolis Moline (which is ADMIREABLE) but have nearly anything LP. Great Folks.
I am looking for the metal shields that cover the filler valves on the left side. I can get the plastic caps, just need two metal shields for two tractors. Thanks
OK, my original presumption was wrong. I now presume that you want the sheet metal guard that surrounds the valve cluster.
Even though that part is bolted to clips on the tank, it is not listed as a separate part number.
I would first call Welters as prviously mentioned. They will need dimensions and tank mfg. I would also seek out salvage yards in the South where most of the LP tractors were used.
If that doesn't work, consider making them yourself using 11 gage (1/8th") stock. Have someone like myself post up some pictures and messurements. The radius can be pressed in an arbor or hydraulic press. Use 4" pipe as an inner die. Not a difficult job.
