Anonymous-0
I am thinking about putting a 6 volt Optmia battery in my H. Has anyone ever done this and where is the best place to purchase. I know they are expensive.
(quoted from post at 20:50:18 11/18/09) Sorry about spelling
(quoted from post at 15:34:23 11/19/09) Those high cold cranking amp are provided by sacrificing reserve capacity. I'll take a cheaper flooded lead acid battery with more amp hours any time.
I admit I have a bit of negative bias since AGMs have so much hyperbole in their advertising. I've had to change-out many failed AGM battery banks, and convert back to conventional flooded lead acid batteries.
Granted, there are advantages to using AGMs in certain applications. I see little advantage in farm tractors.
(quoted from post at 18:20:55 11/19/09) FUN DISCUSSION
AS far as CCA versus reserve capacity seems to me if you need to start a diesel you need highhhhhhhh CCA so she cranks fast enough to raise the temperature of the compressed air sufficient for combustion when the injectors fire and you would be more interested in CCA then reserve to get that fast initial spin. TO THE CONTRARY if you have a gas engine or a worn out engine that takes a while to start and its not so necessary that she cranks really really fastttttt then reserve capacity means more..
To avoid comparing apples to oranges one would need perhaps the Amp Hrs and CCA and Reserve Capacity in order to arrive at the decision as to which battery is best for a particular application. To me that may be high CCA ORRRRR high reserve, depends on the engine. Noooowwwwwwww if one technology (lead acid, Gel cell, AGM, etc) is more efficient and stores more energy due to technology improvements, that may be the best provided theres sufficient real data to make the call???????
