Unknown RED WEIGHT'S
darock
I have a pair of Rear weights the guy said they were for a Cub, Well I paid the guy and took them home and tried to put them on they don't look like the other set on the tractor. I am trying to put two weights per tire The center hole is 8.5" and my other weights are 6"the center of the weights come to a flat spot not to a point like my cub weights do
The weight have a #6701-DA and they have a side ways oval with a letter L in it can any one tell me what they are
Untitled URL Link
Your picture isn't making it though, but the part# sounded awfully familiar. Just took a look in the book to confirm, the weights you have were originally for an A or B/BN.
The mating angles for stacking them are different, so I'm not sure whether they'll be compatible or not. I seem to recall that MAYBE it can be done. See if you can scare up Bigdog either here or over at farmallcub.com. He'll know.
yes they will work. i have a cub that has one set of cub weights and one set of A. B, SA. etc weights. they fit just fine.
Andrew
