relacing transmission/clutch shaft on farmall cub
onehardcase
New User
Replacing the transmission/ clutch shaft on a Farmall cub. How many hours should a budget for this job, and if you fellas have any advice on what I can expect I would really enjoy the help. The shaft is broken right after it come into the trans housing. Thank in advance onehardcase
Thats a pretty easy job if you know what you are doing. I think the first one I did took about 4 hours with all the parts on hand. Today I can do one in about an hour in the shop.
FYI - remember to change the bushing in the flywheel.
