Power take off
Boomer
I have a I.H. 444 gas rig. This summmer the PTO has just started jumping out while mowing or while other wise using the PTO. While running the pTO you can rest your foot on the floorboard and prop your heel against the pto lever and you can feel it trying to jump out but it will stay engaged this way. Any idea what is causing this, loow fluid level? An adjusment that can be made? Any help is greatly appreciated
The detent that keeps the dog clutch engaged, or the teeth on the dog clutch (either, or a combination) will make it happen. I do not know if there is a cover plate to open for access, I hope there is. JimN
