Du - Al Loader / Farmall
magua
New User
hello. does anyone know what model do-al loader will fit a Farmall Super MTA with an after market wide front end? Any thoughts on mounting or plumbing? thanks, tim
also i posted this on the j.d. forum by mistake. if anyone knows how to delete it please do so.
I have a du-al 250 on my m that works good i guess that a 325 or 350 would work as good or better. I run a pto pump with the obvious drawback of no live power. I have heard of guys running a chain off of the front of the crank and cutting a hole in the frame to a pump mounted on the side but I haven't seen that in person. good luck
I have a 400 w/after market wide front. It is a Du-All trip bucket and one-way rams. I also have a Du-All 340 full hydrualic that fit's it.
You have a lot of options depending on what you need and want to do with it.
i have a steep graveled driveway. most of the use will be hauled the rain washed gravel back up the hill. I'm sure i will find many other uses for it as i have 92 acres. thanks for the help.
any idea what other loaders & models might fit the the Super MTA. most of the du-al loaders seem to be in the north central & north western part of the U.S. i'm in central KY. money is an issue. obviously travel to pick up would still be cheeper than giving 6000.00 close to home,just a hassle. thanks for all the help. tim
sorry don't know much about other brands Westendorf makes a god loader but I don't know about the sizes or territory.
