64 706 hydraulic?
Anonymous-0
Hello: I've got a bad hydr leak under the seat on my 706. My queastion is can I somehow shut the pump off so it doesn't leak and still use the tractor? I'm gonna fix the tractor totally this winter, but need it to haul wagons with shortly. Mark R.
You could remove the gear from the pump but by the time you went to that much work you could probably fix the leak with less effort.
