Hi guys...finally got some dry weather to make hay, got the Farmall H out and 1 trip around suddenly it is running like crap. Sputters and spits and stalls out when I try to mow or even put it in gear and go. I pulled the sediment bowl and carb and I have good flow to the carb (cleaned everything anyways, including the jets in the carb). Checked the governor linkage and adjust the idle and power screws on the carb per instructions I found in another post. I pulled the plugs and cleaned them..they had a little build-up. I checked compression...got 90, 120, 100, 110. Could that #1 cylinder be causing the problem? SOmething still screwed up in my carb? I don"t know what else to check.
Any help appreciated.
Justin
Justin
