Farmall Super AV snowplow
Anonymous-0
I recently purchased a Farmall Super AV and it came with a snowplow that is off the tractor. It is an original snowplow for a Farmall Super A to 140. WOuld this snow plow be the same as those on a Super A to 140 or is there differences between the AV hi clear snow plows and regular models. THanks
Jay: I suspect it would be same blade, the only item that would need to be different is the drop frame from tractor down to the pivot of the blade push arms. That blade would have to pivot same distance from ground at the regular SA blade.
I built my own blade for my 130 and when I increased the tractor tire size, I had to lower the push frame pivot. My blade kept riding over the snow. And I only raised the tractor 2.5". About half what your tractor is higher than regular SA.
