help identify steel wheel extensions
railhead
50 inch outside diameter, appears to bolt onto steel wheels to make extensions or "duals". APPEARS to have IHC on some of the square bolt heads. Anyone know diameter of IH steel wheels like on M/H etc?
50 inche wheels were on the 15-30's, 22-36's, and W/WD-40's.
Twin Cities had some of there tractors on 50 inch steel as well. seems like it has too many bolt holes in the wheel to be an IHC extension. I have a set of 42's for my W-30 and will have to check and see if they have that many holes in them
they have 8 bolt on "tabs" around them and 12 steel lugs each. thge guys place I got these from was a Minnie Moline guy but I THOUGHT the square bolt heads had IHC on them....now I am starting to wonder. The rims and lugs are great, marking on the bolt heads are shallow. Woould there be IHC marking on the lugs or rims ifg these were IH? Thanks again.
the lugs, rims, and bolts would NOT have IHC anywhere on them. they usually only put that marking on Cast Iron parts.
if they were from a Minnie Mo guy, id say twin city probably. My 42 inch extensions didnt have near that many bolts holes in them
Those sure look like IH lugs and the way the extensions bolt to the main wheel sure looks like the way IH did it.
