Weight of M rear tire with
R.J.M.T.
would the weight of tractor with tripbucket 5-6
ft wide be about 5to7000lbs.also with bucket on tractor what would you guys think the rear tire would be outside to outside. i have acess to a skid loader trailer 20ft for early mon.morning the tracor is 80 miles,no one lives where tractor is. first red tractor that i own
THANKS guys
r.j.
rear tire width can vary many ways, wheels dished in/out, slid in/out how far?? can be as wide as 9 feet. weight I would say under 7000 pretty safely WITHOUT massive ridiculous amount of rear weight. that trip loader weighs under 400 by itself. I have one that I move by hand to mow around. Take a flatbed with no wheel wells or fenders and you should get it on safely.
I assume the trailer is a "car trailer" with the fenders beside the wheels. If so the M will not fit between the fenders unless at least one wheel is dished in. And if the trailer only has 7000 lbs GVW, the M alone may be too heavy for it depending on how it is equipped. The loader will make it too heavy -- better check the wheels AND the trailer.
