Anonymous-0
I am trying to find a repair kit for a ensign lp regulator for a 350U. Anyone have any sources for such parts as the company went out of bussiness years ago I am told. So far I have struck out. Thanks in advance.
You can make the diaphram. Find a industrial rubber buiness in your area and macth up the material. Punch the holes and your done. Getting the needle attached in the center is a little tricky, but not to bad. I have a 350 utility on L.P. You can also go to the MM disscusion board here and they have numorus places for help. L.P. and Molines go hand in hand!!
Zog, Get a hold of....
Everhart 2-way & LPG Supply
Rt. 1, Box 169
Lone Wolf, Okla.
580-846-5633
He makes rebuild Kits for the old Ensign Carb. and Vaporizers. Hope this helps!
Later,
John A.
