hyd not working
tonastoy
hello again . i have a 450 and the hyd have never worked. the original owner said they did but?? oil in the res says full, took the pump out ,turns fine no grinding or slop. makes no noise when the tractor is running. no noise or whining when i pull any of the control levers. could it have lost prime some how or sucking air ? may be the o rings on the block on the bottom? thanks for any info
It could be the intake screen in the reservoir is so plugged up that it cannot get fluid into the intake. They can be a pain to bleed. See the archives for info on that. JimN
