I got the spiner off my super M to look at the gears. I did'nt see any broken teeth and they did not look worn bad at all. Between the hydraulic reservoir and the trans housing the tractor is loose. There is two large bolts at the top that are tight, but as you go down the side there is a gap that gets larger. About a 1/16 of an inch at the bottom. I see two bolt threads coming into the trans housing at the bottom but it looks like I have to go through the hydraulic reservoir to tighten them up. My question is that the way to do it, go through the hydraulics?Also where can I get a gaskett for the spinner.
thanks
cazz
thanks
cazz
