There is a oil leak where the PTO extends out of the rear end of the 1939 M. I have put a shot of grease in the alimite a couple of times sense rebuilding it, but it seams to be getting worse. Is it complicated to remove the plate and replace the oil seal? Are there any do's and don't's in attempting this project. I have printed the caseIH diagram that shows the different parts to give me an idea. Thanks in advance for any advise. Harley
It should be as simple as it looks. Check the shaft for a wear groove, and either put the new seal in a different location, or use a speedy sleeve to do a serviceable repair. JimN
